New workstation budget 3000,00€ with double GTX670
    Originally posted by Karrde View Post
    I have a build like this (Asus mobo though and Quadro 600), the CPU runs easily at 4,5GHz and Cinebench score is around 13,50. Beast of a machine. I belive you DO need a new computer.
    Sold, specs or it didn't happen. Did you spend ~$3k?
    Colin Senner
      Intel Core i7-3930K @ 4,5Ghz
      Thermalright Silver Arrow
      ASUS P9X79
      4x 8GB DDR3 Kingston HyperX 1600Mhz
      nVidia Quadro 600
      ~2k euro. Purely a 3ds max workstation, hence the Quadro 600. 2000 was out of my financial reach unfortunately.
      edit
      Cost includes drives, case and PSU of course, but that is always personal preference. No SSD though.
        3DKodo, I'm looking at building a similar machine.
        How did this turn out for you?
          Ok, the workstation was assembled!!
          Now i'm waiting for a GTX670 with a problem, no signal video, redelivered in RMA to the vendor! Will he return one new graphic card to me next week!
          For now the workstation is magic!I'm very impressed!
          In this day i'll make some test and after i'll make the overclock of processor 3930K.
          Stay tuned for result!!
          www.kodocreation.com
            Hi to all!!
            After some time with the new workstation...i say that i'm very happy for the purchase!
            Usually i use vrayRT version for make a realtime preview during the set up of the scene, and i think this couple of GTX 670 4GB will stay with me some years at least...they load many poligons and texture without problems!!
            Unfortunately for now Vray RT GPU version is a bit immature compared to the standard version or RT CPU version, and then for now i can't use it very much with my works, but i'm really optimist for next release.
            The other components are another world, compared to my (now second) pc, I7 960!
            For now i've overclocked the new I7 3930K only up to 4Ghz because last month was very hot in italy.....and i'm not used with the liquid cooler!
            In the spare time, i will try to perform other tests for obtain a good saving of render time!
            If you have some test to compare the performance...just ask!!
            • #21
              Can you tell me which features are the most important for your work?
              • #22
                GPU = Shellac mode for additive blending mode... Screen/add.
                • #23
                  Hi Vlado, as main things come to my mind::
                  - Color correction map not supported
                  - Material output settings not supported
                  - Vray material wrapper not supported
                  - Vray proxy inside containers is supported?
                  It would also be very useful to have a better transferring SD tree to cuda devices process and building SDTree for gpu process, because having GPU with 4GB vram this loading process takes several minutes if i use all the vram; but I don't know if this is possible. (With version CPU is much faster)
                  I've posted another thing here!
                  If i'll have another things, i will update this thread!
                  • #24
                    3DKodo,
                    Can you post a benchmark or two? I'm building a new machine this week. Anything you would have done differently? I'm going most of the same components you have and was wondering if you've had any problems or would have done things slightly differently?
                    Colin Senner
                    • #25
                      Btw, this works, but you need to enable the "X-Ref scenes and containers" option in the V-Ray RT settings.
                      • #26
                        I'm buying a new computer, 2 questions:
                        Mobo: Are you happy with the motherboard? I'm thinking about the Rampage IV here, but maybe it's too crazy?
                        http://www.newegg.com/Product/Produc...82E16813131802
                        RE4 HDs: You have 2x of them for 220Euro, is that each or for both?
                        Case: How is it? Big enough? Easy install? Good peripherals?
                        Colin Senner
                        • #27
                          I have the Rampage IV Extreme - Love it!
                          • #28
                            Can you do some kind of benchmark to show the difference from your 920 to the new machine?
                            CHeers
                            Si
                            Simon Askham - http://www.supercreative3d.com Rendering with Threadripper 2990WX Asus Prime X399 36GB DDR4
                            • #29
                              CHeers
                              Si
                              rendertimes from last job:
                              stock 920 1h19min
                              3930k @ 4.4ghz 36mins
                              stock 2600k 55mins
                              3930k is worth every penny
                              • #30
                                Post your overclock voltages if you don't mind, and blk frequencies.
                                Colin Senner
